Installing and Activating RapidWeaver
Learn how to download, install, and activate RapidWeaver
Here we will cover how to download, install, and activate RapidWeaver on your Mac.
Let’s get started.
Step 1
After purchasing RapidWeaver, you will have received a download link which you will use to download the app. When clicking the download link, RapidWeaver will be downloaded to your Downloads folder on your Mac (or a custom folder if you have set a custom folder for your downloads).
In this tutorial we will assume you have left your Downloads folder as the default. Double-click on the RapidWeaver.zip file in order to extract the app.
Step 2
Move (drag and drop) the RapidWeaver app to your Applications folder.
Step 3
RapidWeaver should now be located in your Applications folder. Go ahead and open it.
Step 4
When opening RapidWeaver for the first time, you will be greeted with a registration window. Click on the “Activate License…” button in order to activate the app.
Step 5
Enter the email address you used when purchasing the app, along with the license key you received after your purchase. Then, click the “Activate” button.
Nice work!
Your copy of RapidWeaver should now be activated, and you can start building your very first amazing website!
Last updated
