# Page Not Found
The URL `how-to/apply-anchor-scroll-padding` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [Apply Anchor Scroll Padding](https://docs.realmacsoftware.com/elements-docs/getting-started/how-to/apply-anchor-scroll-padding.md)
- [Adjust Smooth Scroll Speed](https://docs.realmacsoftware.com/elements-docs/getting-started/how-to/adjust-smooth-scroll-speed.md)
- [Add an Icon Inside a Button](https://docs.realmacsoftware.com/elements-docs/getting-started/how-to/add-an-icon-inside-a-button.md)
- [Add Snow to Your Website](https://docs.realmacsoftware.com/elements-docs/getting-started/how-to/add-snow-to-your-website.md)
- [Privacy Policy](https://docs.realmacsoftware.com/elements-docs/legal/privacy-policy.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
GET https://docs.realmacsoftware.com/elements-docs/getting-started/how-to/apply-anchor-scroll-padding.md?ask=<question>&goal=<user_goal>
### Option 2 — Browse the documentation index
Full index: https://docs.realmacsoftware.com/elements-docs/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://docs.realmacsoftware.com/elements-docs/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/elements-docs/getting-started/how-to/apply-anchor-scroll-padding.md`).
You may also use `Accept: text/markdown` header for content negotiation.
