> For the complete documentation index, see [llms.txt](https://docs.realmacsoftware.com/elements-docs/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.realmacsoftware.com/elements-docs/site-quality/.htaccess-file.md).
# .htaccess file
Advanced control for key website settings
The .htaccess file is a simple configuration file used by Apache-based web servers. It lets you control key settings for your website, such as redirect rules, caching, security headers, and more — all without needing access to the server’s main configuration.
For Elements sites, you can use .htaccess to improve security (via headers like CSP and X-Frame-Options), enforce HTTPS, enable compression, and make your site more robust.
Below is a basic, recommended starting point for your .htaccess file.
# Enable URL rewriting (required for pretty URLs, redirects, etc)
<IfModule mod_rewrite.c>
  RewriteEngine On
</IfModule>
# Security Headers
<IfModule mod_headers.c>
  Header always set X-Content-Type-Options "nosniff"
  Header always set X-Frame-Options "SAMEORIGIN"
  Header always set Referrer-Policy "strict-origin-when-cross-origin"
  Header always set Permissions-Policy "geolocation=(), camera=(), microphone=()"
  Header always set Strict-Transport-Security "max-age=63072000; includeSubDomains; preload"
</IfModule>
# Enable Gzip compression
<IfModule mod_deflate.c>
  AddOutputFilterByType DEFLATE text/plain text/html text/xml text/css application/javascript application/json
</IfModule>
# Disable directory listing
Options -Indexes
### Adding an .htaccess file to your website in Elements
Right-click inside the page of your project and choose `New File` from the contextual menu. Name the file `.htaccess` and ensure it is in the root of your website.
<figure><img src="https://3876014504-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FNy6AECEVH2p4eFDicpM1%2Fuploads%2FrERvf951baesyvF3b3I2%2FCleanShot%202025-07-15%20at%2010%E2%80%AF.34.46%402x.png?alt=media&amp;token=795bf5ac-1d51-4292-b512-0440b1978d31" alt="An htaccess file open in the Elements code editor at the project root"><figcaption></figcaption></figure>
### Pretty URLs in Elements CMS
See also: [Pretty URLs](https://docs.realmacsoftware.com/elements-docs/cms/cms/pretty-urls) for instructions on using .htaccess rules to rewrite how URLs are displayed in the CMS.
### CSP (Content Security Policy)
CSP is a security feature implemented via HTTP headers that tells the browser which content it’s allowed to load (like scripts, styles, images, etc). The main goal is to prevent attacks like cross-site scripting (XSS) and data injection by controlling what sources are considered safe.
You can test the security headers for your website at: <https://securityheaders.com>
# Enforce HTTPS
</IfModule>
# Prevent MIME-type sniffing
  Header set X-Content-Type-Options "nosniff"
</IfModule>
# Prevent clickjacking
</IfModule>
# Control referrer information
  Header set Referrer-Policy "strict-origin-when-cross-origin"
</IfModule>
# Control browser features
  Header set Permissions-Policy "geolocation=(), camera=(), microphone=()"
</IfModule>
# Agent Instructions
Perform an HTTP GET request on the current page URL with the `ask` query parameter, and the optional `goal` query parameter:
GET https://docs.realmacsoftware.com/elements-docs/site-quality/.htaccess-file.md?ask=<question>&goal=<endgoal>
`goal` is optional and describes the broader end goal you are ultimately trying to accomplish on behalf of the user. GitBook uses it to tailor the answer towards what is most useful for that goal.
