> For the complete documentation index, see [llms.txt](https://docs.realmacsoftware.com/elements-docs/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.realmacsoftware.com/elements-docs/using-elements/project-and-publishing/previewing-your-website.md).
# Browser Preview
Preview your website in any browser on your Mac
While the WYSIWYG editor allows you to view your design, you'll sometimes want to check how it looks in a browser.
To preview your website in your default browser, you can click the Safari Browser icon in the toolbar (Command-P). You can also press Command-Option-P to choose a different browser.
{% embed url="<https://youtu.be/gDg3POK920s>" %}
### Preview Troubleshooting
For the local network web preview to be available you need to have already Previewed your site locally in the Browser. You can also press the "Restart Web Server" button to start the local preview and generate a new QR Code to scan.
<figure><img src="https://3876014504-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FNy6AECEVH2p4eFDicpM1%2Fuploads%2FQcEAcoxgp2QoTIk2WiyJ%2FCleanShot%202026-02-16%20at%206%E2%80%AF.41.27%402x.png?alt=media&amp;token=ad4e5e3d-7656-4f93-9080-4d8ebc978697" alt="Advanced Project Settings with the Restart Web Server button highlighted"><figcaption><p>Press "Restart Web Server" to start Local Preview</p></figcaption></figure>
Once the web server is running you have two ways of getting the address for your local network preview. Copy and Paste the URL from the Advanced Project Settings, Or point your iPhone at the QR Code.
<figure><img src="https://3876014504-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FNy6AECEVH2p4eFDicpM1%2Fuploads%2FXrFJ0yilJ7SKkTuxoPv4%2FCleanShot%202026-02-16%20at%205%E2%80%AF.21.21%402x.png?alt=media&amp;token=f306d76d-0da1-49e8-aeaf-0bffcb21b673" alt="Advanced Project Settings showing the local preview URL and QR code"><figcaption><p>Scan QR Code to open URL on iPhone or iPad, etc.</p></figcaption></figure>
#### Safari can't open the page
If you cannot see the Preview in Safari, you might be blocking http traffic. Either try another browser, or switch off the "Not Secure Connection Warning" in the Safari Settings.
This setting can be found in `Settings.app > Apps > Safari`.
<figure><img src="https://3876014504-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FNy6AECEVH2p4eFDicpM1%2Fuploads%2FF7Uq7biyctIkG57lP787%2FFile.png?alt=media&amp;token=bf941cde-381f-4351-9f3a-dc79d6dbce11" alt="Safari settings showing where to switch off Not Secure Connection Warning"><figcaption></figcaption></figure>
**Still having local network preview issues?**
* [Follow the advice on this Forum thread](https://forums.realmacsoftware.com/t/need-help-with-network-preview-in-elements-2-0-beta-6/54453).
# Agent Instructions
GET https://docs.realmacsoftware.com/elements-docs/using-elements/project-and-publishing/previewing-your-website.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `build a script that syncs our docs to a CMS` lets GitBook tailor the answer to that use case.
